stanfrench
Aug 23, 2024Luminary
RS700S not delivering 1.5Gbps
I recently upgraded my modem and router so I could add more devices and get higher speeds. I purchased the Netgear Nighthawk CM2000 cable modem and the Nighthawk RS700S Wifi 7 router. According to th...
stanfrench
Aug 26, 2024Luminary
Bingo! Changing the channel assignments from Auto to 1, 40 and 69(PSC) for 2.4 GHz, 5 GHz and 6GHz respectively did it. Thank you so much. I just ran a speed test and got 1,315 Mbps standing next to the router (incoming to the router was 1,630). 80% throughput works for me.
Apple suggests a single-name SSID (i.e., Smartconnect) but I'm reluctant to do that as I have a large coverage area and not sure how smart the connection really is. I'm glad I don't have to go to that step as it would involve a lot of device reconfiguring.
All is good now, thanks again.
Aug 26, 2024Guru - Experienced User
Woo Hoo.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
