TeamCorvette
Feb 06, 2024Tutor
RS700s PC Clients cannot be seen on same workgroup
I never had this issue with older Netgear routers in that all P/C MS Window clients assigned to same Windows workgroup cannot see each other even though in this RS700 it also has the same name for wo...
ShadowMario3
Feb 06, 2024Luminary
Did you make sure your Windows PCs are set in Private network mode instead of Public?
michaelkenward
Feb 06, 2024Guru - Experienced User
That one bit me today.
After much faffing around with m odems and routers to get my ISP accept that its network was bust and not my system, I found that the desktop Speedtest App would not connect.
Lo and behind, the network had gone public during the changes.
Flick to private and Speedtest jumped into action.
- TeamCorvetteFeb 06, 2024Tutor
Please expand on this as MS Windows either allows setting the P/Cs to a domain
or a workgroup which is what all my P/Cs as clients and server are with the same workgroup name
They always saw each other with other Netgear routers but went blind when using this RS700
Were is the stting for private,?
is this a router setting, if so where or where as to MS Windows settings as all I see is domain which never used, but as workgroups which is also what the RS700 has a setting for and also set to the same workgroup name ?
Thanks
- michaelkenwardFeb 06, 2024Guru - Experienced User
New router = New Network = Windows amnesia (See above)
Were is the stting for private,?Which version of Windows?
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
In Windows 11:
- schumakuFeb 06, 2024Guru - Experienced User
Start with enabling the Windows Features for SMB 1.0/CIFS Client and SMB 1.0/CIFS Server. At the same moment, untick the SMB 1,0/CIFS automatic removal.
Doing so does also enable the Netbios name resolution and the host announcement.
The name of the workgroup (default: WORKGROUP) is pure informational, and has no logical impact on security.
