olegeezer
Jan 30, 2025Guide
RS700S V1.0,7,96_2.0.96 slows speed
Hello again. I downloaded RS700S V1.0.7.96_2.0.96ck and as a result, my download and upload speeds slowed down. It continued even after I updated all drivers on my OS and reset my RS700S to factory s...
Jan 29, 2025Guru - Experienced User
So this fixed the speed issues then?
olegeezer
Jan 30, 2025Guide
I had to enable QoS before I could update download and upload speeds in 192.168.1.1.
I had to roll back the new firmware V1.0.7.96 because it was slowing my internet speed.
- FURRYe38Jan 31, 2025Guru - Experienced User
Did you try a factory reset and setup from scratch when v1.0.7.96 was loaded?
Was Protection Engine enabled at the time?
- olegeezerJan 31, 2025Guide
Hello. Yes, I did a factory reset while having V1.0.7.86. Then I installed V1.0.7.96 firmware and did a factory reset again. But my speeds slowed down and fluctuated. So, I rolled back to V1.0.7.86, did a factory reset and my speeds returned to 1250 and 1260Mbps.
Thanks, Matt
- BH_CJan 31, 2025NETGEAR Expert
RS700 does not support Router Protection at this point.
Just to clearify this, to run speed test, you need to disable QoS first, that is, from the router's web GUI, uncheck the "Enable QoS" and clikc the "Apply" buttom to make the change effective.
When you check the "Enable QoS" function without clicking the "Apply" button, no changes are made and no router functions should be impacted.
