jmiltons
Sep 24, 2023Aspirant
RS700S What gives with the lack of documentation
I finally received my much awaited RS700. I am very excited to get it set up and see what it can do. However, I am struggling with the lack of availability of documentation. From the Netgear site the...
Sep 24, 2023Guru - Experienced User
Agreed, not like NG to not have a UM with new stuff. May still be in development and editing. Will need to be patient on this.
What Browser are you using?
What FW is loaded?
You can't select NONE or any of the other two items? Looks like this maybe a bug.
jmiltons
Sep 25, 2023Aspirant
Thanks, I have used several browsers: Edge, Chrome, and FireFox but with the same result. I will give it some time to see if docs are still under review.
- ShadowMario3Sep 25, 2023Luminary
Are you not able to uncheck the box? I'm able to on the latest FireFox with no issue. Here's an image of what I am talking about:
Once you uncheck it, the other security options should no longer be grayed out.
