jmiltons
Sep 24, 2023Aspirant
RS700S What gives with the lack of documentation
I finally received my much awaited RS700. I am very excited to get it set up and see what it can do. However, I am struggling with the lack of availability of documentation. From the Netgear site the...
ShadowMario3
Sep 24, 2023Luminary
I believe that the reason that they are grayed out is because you would use the same SSID for the 2.4 GHz, 5 GHz, and 6 GHz wireless bands. The WPA2 Personal and WPA3 Personal security options are the only type of security that overlaps all three bands.
If you uncheck "Enable Smart Connect" near the top, those options will no longer be grayed out for their respective bands.
jmiltons
Sep 25, 2023Aspirant
Maybe? but the consolidated SSD is turned on for both devices. I bet that documentation would tell me that. 🤣
- schumakuSep 26, 2023Guru - Experienced User
... it's probably your first device including a 6 GHz Wi-Fi radio. While this is not about 801.11be, WPA3 or for the sake alternatively OWE are mandatory for 6 GHz.
