teaguew
May 18, 2025Aspirant
RS90 LAN LED flashing red/orange
I'm not sure whether of the color ... it's either red or orange and flashing. The closest solution I can find was to update the firmware. I checked and it's the latest version. Devices connecting...
- May 18, 2025
What does the user manual give for LED colors for your router?
What device is connected to the LAN port?
Happens when connected to other LAN ports?
teaguew
Colors: white and amber. So I guess it's amber and blinking. Manual says if it's blinking it has traffic at a lower speed.
Three devices connected to LAN, two security camera NVRs and a laptop.
Re your third question, are you asking what if I move the ethernet cables to other LAN ports on the router? Since the color I see must be amber, it would seem that's likely not an issue.
Thanks for putting me on the right track!
- FURRYe38May 18, 2025Guru - Experienced User
Ya, high speed 1Gb or higher should be white. Anything lower then that would be AMBER.
Enjoy.
