jgcarducci
Feb 06, 2024Initiate
Sansung c460 printer attaches to wifi but isn't visible on network
My Samsung c460 printer attaches to the network, I can see it and its IP address from the router but no PC on my network can access it. Its status is offline. I'm not using the router's access contro...
- Feb 06, 2024
I realized where I went wrong; completely my fault. It had been so long that I'd configured my printer that I'd forgotten I'd 1( specified a static IP and 2) used a different subnet mask. Corrected these and now printer is visible network wide.
Haste makes waste.... please close this thread.
Jerry
Feb 06, 2024Guru - Experienced User
make sure your pc's are setup for a private network and not set on public.
