ForestCat
Aug 01, 2025Guide
Slow AX200 (WiFi 6) connection to RS500 - but with a partial solution
Thought I would share an issue I was running into with my RS500 on firmware 1.0.1.90 that caused me hours of searching trying to fix and how I was able to resolve the issue. Let me describe. My w...
Aug 04, 2025Guru - Experienced User
When you set it to "up to 2900mbps" on the 5ghz its sets the width from 160hz to 80hz. It could be the AX200 is having issues with 160hz wide channels. Or the dfs channels in your area.
What driver model is on the AX200?
ForestCat
Aug 04, 2025Guide
Thank you so much for the response. I was wondering if this might be a channel width issue but was unsure how to determine that. I have the AX200 on Intel’s latest driver 23.150.0.
