ForestCat
Aug 01, 2025Guide
Slow AX200 (WiFi 6) connection to RS500 - but with a partial solution
Thought I would share an issue I was running into with my RS500 on firmware 1.0.1.90 that caused me hours of searching trying to fix and how I was able to resolve the issue. Let me describe. My w...
Aug 05, 2025Guru - Experienced User
If you do a quick google search, you can see a bunch of posts with issues on the AX200 and 160hz wide channels. Everything from driver issues, wrong settings for the card, hardware issues with built in cards, and bios power management. Might check that motherboard specifics to see if anyone else has had issues with is since its mainly that specific device
ForestCat
Aug 06, 2025Guide
Appreciate the comment. For those that are curious, this is on an ASUS ROG Strix X570-I gaming motherboard running BIOS 5301.
At one point I considered swapping out the Wi-Fi chip on this motherboard but the number of shrouds, tiny screws, etc. to access it were going to take more time than I had.
As I responded to RichardTTT below, I decided to just go with a Netgear A9000 USB Wi-Fi adapter to resolve my issue. It works great and, due to me starting a new job, don’t have time to troubleshoot this further.
