Camreckem
Oct 25, 2024Aspirant
Slow download speed shortly after modem restart
I've been having issues with slow download speed on my home network. Initially I thought it was an issue with my ISP's modem/router combo. My speeds would slow to 30mb down from my advertised 500mb d...
Camreckem
Oct 26, 2024Aspirant
Expected is 500 down 50 up, actual is ~30 down 50 up. I get 500 down right after rebooting the modem, then 5mins-1hr later it drops to 30 down. Speeds were taken from a laptop plugged directly into the modem with the cat5e cable that came with the modem. Speeds are the same when performed on wifi (within margin of error)
I have an ISP tech coming out Monday, so hopefully that will shed some light on the issue if not resolve it.
Oct 26, 2024Guru - Experienced User
If that is happening with the direct connection to the modem, then the ISP will need to check everything. Have them review the connections status page and event logs data.
