bcas400g64
Dec 22, 2024Aspirant
Slow PS5 downloads wired connect RS200
Hello, Just got the RS200 Nighthawk and while my wireless speeds for phones/and other devices is great, it's 1/2 the download speed I had on older router. I was getting over 500mbps and now just...
Dec 23, 2024Guru - Experienced User
Try enabling Armor then disable Protection Engine on the RS.
DarrenM
Dec 23, 2024Sr. NETGEAR Moderator
You might want to try to whitelist the PS5 in Armor
How to create a Netgear Armor device exception:
- Open the app: Launch the Netgear Nighthawk or Orbi app on a device connected to your network.
- Navigate to Security: Go to the "Security" section of the app.
- Access device management: Find the option to manage connected devices.
- Select the device: Choose the specific device you want to allow access to.
- Set exception: Mark the device as "allowed" or "trusted" to create the exception.
