niceguy235
Jul 20, 2024Tutor
Slow Upload Speed RS300
Just got an RS300 all up and running, but i am getting extremely poor upload speeds. I am on a 2gb/2gb ISP connection and i can get full download but barely 700 on upload from webgui or app. ...
Jul 20, 2024Guru - Experienced User
schumaku wrote:
Just curious: Does the built-in Speedtest now have the ability to select a different server?
Not that I'm aware of. And thats been an issue before with the default test server not being able to saturate lines. It used to be a bigger issue as some test servers couldn't saturate gigabit. That's gotten better. But now we're bumping up >2gig speeds and reciprocal speeds. Could be a thought that the test is hosted from different servers.
niceguy235
Jul 20, 2024Tutor
There is no drop down for selecting a different server on mine either.
- DarrenMAug 09, 2024Sr. NETGEAR Moderator
niceguy235 Are you still seeing poor upload speeds on wifi?
- niceguy235Aug 10, 2024Tutor
Yes i am.
I do check for any new firmware as i have it set manually so that i know.
- DarrenMAug 12, 2024Sr. NETGEAR Moderator
I will look into this, bring it to the attention of the engineers, and get back to you.
Thanks
DarrenM
