autoexec_bat
Feb 13, 2024Apprentice
Slow upload speeds on router Speedtest
Observing an interesting situation with upload speeds on my RS700 connected to a Verizon ONT, fiber gigabit. The upload Speedtest on the RS700 tops out at about 300-ish Mbps; at the same time a hard...
- Jul 03, 2024
For some reason I can't reply to my original topic (https://community.netgear.com/t5/Nighthawk-with-WiFi-7-BE/Slow-upload-speeds-on-router-Speedtest/td-p/2363429) so I will post an update here. After swapping ONTs for VZW's 2Gbit service I am able to max out downloads and uploads. The internal RS700 test showed 2,455 Mbps down and 2,495 Mbps up. Wifi gets around 1,500 down and 1,500 up which is ok for wireless. At this point I am 100% certain that the issue is specifically with RS700 and G-211M-C ONTs. So if any of you have issues with uploads and have Verizon's 1Gbit service running on their G-211M-C ONT, your only solution at the moment is to swap ONTs by requesting a 2Gbit service (you can make a call afterwards to downgrade, they will simple provision for lower speeds but you get to keep the new ONT). Alternatively, you can look for a new router 🙂
Feb 13, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
If the Verizon unit has a built in router, disabling WiFi won't be enough.
Does the Verizon ONT have 2.5Gb Ethernet ports?
autoexec_bat
Latest fw, V1.0.7.82_2.0.80. Cable is CAT6A STP. There is no Verizon router in between, it goes ONT > RS700.
The VZW ONT is G-211M-C which has 1Gbit full duplex port.
The ONT is not the bottleneck as the other attached device (AppleTV via RS700) pushes near gigabit.
Hardwiring a laptop to the RS700 also gets near 100% saturation down and up.
