autoexec_bat
Feb 13, 2024Apprentice
Slow upload speeds on router Speedtest
Observing an interesting situation with upload speeds on my RS700 connected to a Verizon ONT, fiber gigabit. The upload Speedtest on the RS700 tops out at about 300-ish Mbps; at the same time a hard...
- Jul 03, 2024
For some reason I can't reply to my original topic (https://community.netgear.com/t5/Nighthawk-with-WiFi-7-BE/Slow-upload-speeds-on-router-Speedtest/td-p/2363429) so I will post an update here. After swapping ONTs for VZW's 2Gbit service I am able to max out downloads and uploads. The internal RS700 test showed 2,455 Mbps down and 2,495 Mbps up. Wifi gets around 1,500 down and 1,500 up which is ok for wireless. At this point I am 100% certain that the issue is specifically with RS700 and G-211M-C ONTs. So if any of you have issues with uploads and have Verizon's 1Gbit service running on their G-211M-C ONT, your only solution at the moment is to swap ONTs by requesting a 2Gbit service (you can make a call afterwards to downgrade, they will simple provision for lower speeds but you get to keep the new ONT). Alternatively, you can look for a new router 🙂
autoexec_bat
Feb 14, 2024Apprentice
BH_C here are some more tests:
MacBook hardwired to RS700 which is hardwired to Verizon's ONT (used a USB-C to LAN adapter as MacBooks don't have LAN ports)
...and just a few seconds later that same MacBook os now hardwired directly yo Verizon's ONT (so RS700 is removed from the chain); same test servers:
BH_C
Feb 14, 2024NETGEAR Expert
Thank you autoexec_bat, I will check with the team to see the next step to debug the issue.
