autoexec_bat
Feb 13, 2024Apprentice
Slow upload speeds on router Speedtest
Observing an interesting situation with upload speeds on my RS700 connected to a Verizon ONT, fiber gigabit. The upload Speedtest on the RS700 tops out at about 300-ish Mbps; at the same time a hard...
- Jul 03, 2024
For some reason I can't reply to my original topic (https://community.netgear.com/t5/Nighthawk-with-WiFi-7-BE/Slow-upload-speeds-on-router-Speedtest/td-p/2363429) so I will post an update here. After swapping ONTs for VZW's 2Gbit service I am able to max out downloads and uploads. The internal RS700 test showed 2,455 Mbps down and 2,495 Mbps up. Wifi gets around 1,500 down and 1,500 up which is ok for wireless. At this point I am 100% certain that the issue is specifically with RS700 and G-211M-C ONTs. So if any of you have issues with uploads and have Verizon's 1Gbit service running on their G-211M-C ONT, your only solution at the moment is to swap ONTs by requesting a 2Gbit service (you can make a call afterwards to downgrade, they will simple provision for lower speeds but you get to keep the new ONT). Alternatively, you can look for a new router 🙂
BH_C
Feb 14, 2024NETGEAR Expert
Thank you autoexec_bat, I will check with the team to see the next step to debug the issue.
autoexec_bat
Feb 15, 2024Apprentice
Hey BH_C more testing this morning, with some interesting results:
SETUP A: MacBook hardwired to RS700 which is hardwired to Verizon's ONT:
SETUP B: MacBook hardwired to Verizon's ONT (removed RS700 in between):
SETUP C: MacBook hardwired to MikroTik hEX (router) which is hardwired to Verizon's ONT, RS700 also hardwired to MikroTik hEX; RS700 is an AP Mode and routing is done by MikroTik:
You can see that removing the RS700 from the equation resolves upload speeds. When RS700 is switched to AP mode, and the MikroTik router is inserted between the ONT and RS700, doing all the routing, then RS700 can finally max out its own upload test. With this setup, all uploads from hardwired clients max out; however uploads via wifi are still very slow.
