autoexec_bat
Feb 13, 2024Apprentice
Slow upload speeds on router Speedtest
Observing an interesting situation with upload speeds on my RS700 connected to a Verizon ONT, fiber gigabit. The upload Speedtest on the RS700 tops out at about 300-ish Mbps; at the same time a hard...
- Jul 03, 2024
For some reason I can't reply to my original topic (https://community.netgear.com/t5/Nighthawk-with-WiFi-7-BE/Slow-upload-speeds-on-router-Speedtest/td-p/2363429) so I will post an update here. After swapping ONTs for VZW's 2Gbit service I am able to max out downloads and uploads. The internal RS700 test showed 2,455 Mbps down and 2,495 Mbps up. Wifi gets around 1,500 down and 1,500 up which is ok for wireless. At this point I am 100% certain that the issue is specifically with RS700 and G-211M-C ONTs. So if any of you have issues with uploads and have Verizon's 1Gbit service running on their G-211M-C ONT, your only solution at the moment is to swap ONTs by requesting a 2Gbit service (you can make a call afterwards to downgrade, they will simple provision for lower speeds but you get to keep the new ONT). Alternatively, you can look for a new router 🙂
BH_C
Feb 15, 2024NETGEAR Expert
Thanks autoexec_bat for the updates. The weird thing is the Apple TV is OK and the speed test is OK in other places.
We will check how to dig out more clues to fix the issue.
autoexec_bat
Feb 15, 2024Apprentice
Thanks BH_C . Wifi is still very constricted though on the upload, no matter the setup / test / client. Not sure if you saw this, it's a 2nd unit I am working with as I exchanged it, thinking that 1st one was defective.
- BH_CFeb 16, 2024NETGEAR Expert
Hi autoexec_bat ,
When you said "Wifi is still very constricted though on the upload", did you refer to MacBook Pro or other devices?
MacBook Pro (over wifi 5GHz ax) iPerf 3 from / to NUC: 702Mbps down / 440Mbps up
It looks iPhone 15 Pro is good:
iPhone 15 Pro (over wifi 6GHz 6e) iPerf 3 from / to NUC: 1.5bps down / 1.2Gbps up
We didn't see speed issue in our test. Please let us know the exact model with which you got slow upload speeds. Thanks.
- autoexec_batFeb 16, 2024Apprentice
Hi BH_C
Quoting from before, updated the incorrect MacBook upload which is constricted uploading to WAN.
Yes, the iPhone 15 Pro over wifi is outstanding on the internal network, however it drops to 100Mbps to WAN.
HP EliteBook 845 G8 is also constricted to slow upload to WAN over wifi. Pretty much all uploads except ATV.
- RS700 internal Speedtest: 900Mbps down / 345Mbps up
- Intel NUC (over ethernet) iPerf 3 to / from any internal network client: 950Mbps down / 950Mbps up
- Intel NUC (over ethernet) LibreSpeed to any NY server: 900Mbps down / 300Mbps up
- Intel NUC (over ethernet) Ookla Speedtest CLI to any NY server: 920Mbps down / 260Mbps up
- iPhone 15 Pro (over wifi 6GHz 6e) iPerf 3 from / to NUC: 1.5bps down / 1.2Gbps up
- iPhone 15 Pro (over wifi 6GHz 6e) Ookla Speedtest to any NY server: 900Mbps down / 100Mbps up
- AppleTV 4K (over ethernet) iPerf 3 from / to NUC: 941Mbps down / 943Mbps up
- AppleTV 4K (over ethernet) Ookla Speedtest to any NY server: 933Mbps down / 940Mbps up
- MacBook Pro (over wifi 5GHz ax) iPerf 3 from / to NUC: 702Mbps down / 400Mbps up
- MacBook Pro (over wifi 5GHz ax) Ookla Speedtest to any NY server: 500Mbps down / 100Mbps up
- HP EliteBook 845 G8 (over wifi 5GHz ac) Ookla Speedtest to any NY server: 500Mbps down / 300Mbps up
- HP EliteBook 845 G8 (over ethernet) Ookla Speedtest to any NY server: 500Mbps down / 300Mbps up
