autoexec_bat
Feb 13, 2024Apprentice
Slow upload speeds on router Speedtest
Observing an interesting situation with upload speeds on my RS700 connected to a Verizon ONT, fiber gigabit. The upload Speedtest on the RS700 tops out at about 300-ish Mbps; at the same time a hard...
- Jul 03, 2024
For some reason I can't reply to my original topic (https://community.netgear.com/t5/Nighthawk-with-WiFi-7-BE/Slow-upload-speeds-on-router-Speedtest/td-p/2363429) so I will post an update here. After swapping ONTs for VZW's 2Gbit service I am able to max out downloads and uploads. The internal RS700 test showed 2,455 Mbps down and 2,495 Mbps up. Wifi gets around 1,500 down and 1,500 up which is ok for wireless. At this point I am 100% certain that the issue is specifically with RS700 and G-211M-C ONTs. So if any of you have issues with uploads and have Verizon's 1Gbit service running on their G-211M-C ONT, your only solution at the moment is to swap ONTs by requesting a 2Gbit service (you can make a call afterwards to downgrade, they will simple provision for lower speeds but you get to keep the new ONT). Alternatively, you can look for a new router 🙂
autoexec_bat
Jul 03, 2024Apprentice
Jul 03, 2024Guru - Experienced User
Great to hear. Does seem like there is a problem with the RS and that particular model ONT. Glad the new different model is working. Hoping NG can figure it out.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
