idevelop
May 31, 2024Aspirant
slow upload speeds RS700
I just purchased the RS700 and got it setup and when running multiple hardwired speedtests on multiple different servers I can't hit above 250~Mbps on upload. Download speeds are 900+Mbps as expected...
BH_C
Jun 01, 2024NETGEAR Expert
Which internet service provider do you use?
idevelop
Jun 01, 2024Aspirant
Verizon Fios 1gb up/down
- BH_CJun 01, 2024NETGEAR Expert
We noticed this issue for some Verizon fiber customers and looks there is an Ethernet interoperability issue between the RS700's internet port and a certain Nokia ONT providied by Verizon. We still work on this issue. Can you send me a photo of the product label on your ONT through a private message? Thanks.
- AtaggJun 01, 2024AspirantHi, one of the friends here. Have fios 1gb up and down. Before installing the rs700 i had fios router. Swapped over got same issue as OP. My only fix was to bridge the network to the rs700 using the fios router. I have everything working getting my full speeds now but still have a piece of hardware (fios router) wasting electricity now. You mentioned NOKIA ONT device, my ONT is the Alcatel I-211M-L. I tried doing troubleshooting with Verizon and got nowhere no matter what I tried it just wouldn't get full speeds unless that fios router was connected in front of the rs700.
- Rob1099Jun 09, 2024Star
Thanks for this thread. I, too, am scratching my head with the RS700 and Fiber FIOS performance.
I purchased the RS700 yesterday 06/08/2024. It's connected with a brand-new Cat6A cable from the RS700 to the Frontier (formerly Verizon FIOS) ONT. (I tried it with previous cat5e cable run too, no difference at all, ONT to RS700 cable is not a variable here)
The ISP WAN speeds I pay for are 1gb up/down symmetrical. Historically I get at or above these speeds on my previous Linksys MX5300 Velop units. (DFW Area, great new fiber residential infrastructure)The ONT I have is an Acatel-Lucent 1-211M-L.
I've only had the RS700 for one day but some odd findings so far:
- WAN ISP Speeds when plugged directly into the ONT are as-expected, up/down.
- WAN ISP Speeds on my Linksys Velop MX5300 that this is replacing are consistently right around the 1Gbps speed up and down, perfect.
- Wired devices into the RS700 are decent, but still about half of what they were wired into my Linksys MX5300 (I'm getting around ~400 mbps up, nearly half of the wired speeds on those same exact clients, same network cables, same everything)
- Wireless upload speeds via WAN are really bad, on Wi-Fi 5, Wi-Fi 6, and 6E clients, literally 40 - 90 MBPS consistently. 10 feet away from the router
- Download speeds via Wireless on the RS700 seem decently respectable
Netgear I appreciate you responding here and highlighting what you say may be an issue.
If there's anything I can provide to help, just let me know. Concerning and I really want this RS700 to work out for me.
- zeussJun 09, 2024Tutor
I have a suggestion that might be helpful for the Netgear team's analysis, though I'm not sure if you'd like to try it.
You can set up your RS700 in AP Mode, then move your WAN cable from the WAN port to one of the LAN ports (1/2/3/4). Connect your wired PC to another LAN port and check if you get better speeds.
After that, with the same AP mode setup, move the WAN cable back from the LAN port (1/2/3/4) to the WAN port. Then, see if the speed remains improved or if it drops again.
