idevelop
May 31, 2024Aspirant
slow upload speeds RS700
I just purchased the RS700 and got it setup and when running multiple hardwired speedtests on multiple different servers I can't hit above 250~Mbps on upload. Download speeds are 900+Mbps as expected...
autoexec_bat
Jun 07, 2024Apprentice
Nokia and Alcatel are the same company, so the I-211M-L is identical to the G-211M-C.
There is an upload speed issue of some sort with RS700 and I-211M-L / G-211M-C on Verizon.
I saw someone else recommend a 3rd device in between as a fix, need to try that myself.
Jun 09, 2024Guru - Experienced User
Might try a non managed switch in between the Verizon ONT and the RS. Maybe GS105 or GS305 switch.
