idevelop
May 31, 2024Aspirant
slow upload speeds RS700
I just purchased the RS700 and got it setup and when running multiple hardwired speedtests on multiple different servers I can't hit above 250~Mbps on upload. Download speeds are 900+Mbps as expected...
autoexec_bat
Jun 11, 2024Apprentice
You can check my original thread here, I've done quite a lot of testing: https://community.netgear.com/t5/Nighthawk-with-WiFi-7-BE/Slow-upload-speeds-on-router-Speedtest/td-p/2363429
The details in Rob1099 's post match my situation nearly to the T. I am working on FW testing as well together with BH_C.
Ironically it's good to validate that others have an identical issue, at least I know it's not something on my end alone.
Having said that, I really hope this gets a bit more resource on NETGEAR's side as it is clearly a problem that needs work. I imagine millions of potential Customers will be eventually / are already affected, FIOS is not a small provider.
Rob1099
Jun 11, 2024Star
Thanks autoexec_bat for your time and help on this. Looks like you've been chasing it down for several months already. I don't want to return this router but that's a long time, props for the work you've done already.
Quick question for you, BH_C and others here.... do we know if a different model ONT performs better / as-expected? I'm going to try and get a different ONT from Frontier (for semi-unrelated reasons) and I'm curious if this software bug is related specifically to the Alcatel-Lucent 211M-L ONT or if it's a bug for Fiber ONTs at large? Perhaps we don't know?
Thanks again,
Rob
- FURRYe38Jun 11, 2024Guru - Experienced User
Would be good to know if a GS series non managed switch could be a alternative or work around for this issue, until NG can figure this out.
- Rob1099Jun 11, 2024Star
Hi FURRYe38 - are we talking a simple Ethernet connection from ONT into unmanaged L2 like a GS108, and then Ethernet GS108 into the WAN port of RS700?
The way my home network is physically and logically setup, I can make that work (for a short-term, temporary test) with minimal headache.Let me know if so, I can confirm back?
Sincerely,
Rob
Yes. Would be great to see if anything changes. Just don't connect anything else to the switch. Just the ONT and the RS.
- ShadowMario3Jun 11, 2024Luminary
"do we know if a different model ONT performs better / as-expected?"
I have a Nokia ONT XS-010X-Q through GoNetspeed. I have no issues with getting 2 gig Internet on both download and upload.
Great info, thanks ShadowMario3
