idevelop
May 31, 2024Aspirant
slow upload speeds RS700
I just purchased the RS700 and got it setup and when running multiple hardwired speedtests on multiple different servers I can't hit above 250~Mbps on upload. Download speeds are 900+Mbps as expected...
idevelop
Jun 01, 2024Aspirant
I have Verizon fiber 1gb up/down.
I am using Speedtest.net on multiple different servers.
And again, if I use my XR1000 I get above 900 on both up/down with a wired connection.
I am a system engineer as my day job the reason I posted here is because I have 2 other friends that bought the rs700 yesterday (micro center was doing $200 off) and all 3 of us are capped around 200~ on a wired connection. We all have Verizon 1gb up/down. 3 different local cities. Each 20+ minutes away from each other and we are all having the same issue.
Jun 14, 2024Guru - Experienced User
Any progress on this?
Have you tried putting in a non managed switch in between the ONT and the RS?
Might ask the ISP about changing out the ONT. Seems like there maybe an issue between these certain branded ONTs and RS units.
