jaimea
Jun 22, 2026Aspirant
Starlink Router
I bought a Netgear Nighthawk RS300 to be used with Starlink. I viewed a video that showed that you may not use the Starlink router and connect your own router directly to the Starlink power base and...
Jul 08, 2026Guru - Experienced User
Any progress on this?
