2meter2
Mar 18, 2025Aspirant
Suddenly no internet connection nighthawk rs 300, ISP is working fine,
The product stopt passing through internet. The isp is working fine Tried factory reset, After it it said connected to internet for a moment and now dead again. What should I do?
- Mar 26, 2025
Ok if it's in router mode, then use the Yellow WAN port. Even AP mode uses the Yellow WAN port.
I'd be sure the ISP router has the DMZ or IP-pass thru enabled for the RS router if it's in router mode.
Mar 18, 2025Guru - Experienced User
what modem/gateway from the ISP is it connected to?
What are the lights on the router doing? color/blinking/etc.
2meter2
Mar 19, 2025Aspirant
First of all, thank you for replying me, i attached a Gif file showing the lights blinking. I'm still not having internet with this RS300. Althought the app says there is one.
Yesterday I changed back to my old Nighthawk R7000 ac 1900 and internet works perfectly. But that is not the solution I'm looking for.
- 2meter2Mar 19, 2025Aspirant
I tried something new, I changed the connected port from "internet port" (where it worked without problems for 2 weeks or so) to "multi gig internet"-port 4. There it seams Internet is working fine.
It only says:
Error: Unable to establish WAN aggregation. (printscreen attached)
