2meter2
Mar 18, 2025Aspirant
Suddenly no internet connection nighthawk rs 300, ISP is working fine,
The product stopt passing through internet. The isp is working fine Tried factory reset, After it it said connected to internet for a moment and now dead again. What should I do?
- Mar 26, 2025
Ok if it's in router mode, then use the Yellow WAN port. Even AP mode uses the Yellow WAN port.
I'd be sure the ISP router has the DMZ or IP-pass thru enabled for the RS router if it's in router mode.
2meter2
Mar 19, 2025Aspirant
I tried something new, I changed the connected port from "internet port" (where it worked without problems for 2 weeks or so) to "multi gig internet"-port 4. There it seams Internet is working fine.
It only says:
Error: Unable to establish WAN aggregation. (printscreen attached)
Mar 19, 2025Guru - Experienced User
thats fine but still don't know what modem/gateway its connected to?
- 2meter2Mar 19, 2025AspirantThe modem it’s connected to is a Sunrise connect box 3, (ISP sunrise, Switzerland) the manufacturer brand is Sagemcom. I hope this is more helpful for you
- 2meter2Mar 19, 2025AspirantI attached a photo of the modem description plate
- FURRYe38Mar 20, 2025Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
Try option #2 first...
2meter2 wrote:
I attached a photo of the modem description plate- 2meter2Mar 21, 2025Aspirant
Option 2 was similar to how I had it configured. The only thing I don't understand is why it worked without any issues before and then suddenly stopped working after several weeks.
Switching from "internetport" to "multi gig internet" now works fine for me. I hope it remains this way, or perhaps I can change back in the future or I start using the ISP's router. Time will tell.
Thank you for your support, and I wish you a pleasant day!
