2meter2
Mar 18, 2025Aspirant
Suddenly no internet connection nighthawk rs 300, ISP is working fine,
The product stopt passing through internet. The isp is working fine Tried factory reset, After it it said connected to internet for a moment and now dead again. What should I do?
- Mar 26, 2025
Ok if it's in router mode, then use the Yellow WAN port. Even AP mode uses the Yellow WAN port.
I'd be sure the ISP router has the DMZ or IP-pass thru enabled for the RS router if it's in router mode.
2meter2
Mar 26, 2025Aspirant
I’m using now Port 4 lan which is also yellow marked with internet aggregation. I turned off all WiFi connections on the router from my ISP and didn’t change any other settings, so I think it’s still in router mode.
Mar 26, 2025Guru - Experienced User
