Oblique's avatar
Oblique
Suggestion for expander/mesh RS700
I live in Australia and I am looking at RS700 as my main router - but I also have a separate studio office with ethernet line to the main router - looking for an expander with 3-4 ethernet ports to w...
  • FURRYe38's avatar
    When you ethernet connect up the EAX in AP mode, the EAX effectively is using this same ethernet cable from the host router as a BH. So anything connecting wirelessly or wired to the other ports will go thru this one ethernet cable from the host router to the EAX. This is NOT MESH though.
