Oblique
Nov 12, 2023Aspirant
Suggestion for expander/mesh RS700
I live in Australia and I am looking at RS700 as my main router - but I also have a separate studio office with ethernet line to the main router - looking for an expander with 3-4 ethernet ports to w...
- Nov 12, 2023
When you ethernet connect up the EAX in AP mode, the EAX effectively is using this same ethernet cable from the host router as a BH. So anything connecting wirelessly or wired to the other ports will go thru this one ethernet cable from the host router to the EAX. This is NOT MESH though.
Nov 12, 2023Guru - Experienced User
Yep, Only get 5Ghz AC and AX modes but should connect up in AP mode and provide good wifi and wired connections in the remote area.
Oblique
So I note it has 4 ethernet ports - but can I use one of them as ethernet backhaul to the original router? I have an Ethernet cable to achieve this but I am not sure if it is compatible
