Oblique
Nov 12, 2023Aspirant
Suggestion for expander/mesh RS700
I live in Australia and I am looking at RS700 as my main router - but I also have a separate studio office with ethernet line to the main router - looking for an expander with 3-4 ethernet ports to w...
- Nov 12, 2023
When you ethernet connect up the EAX in AP mode, the EAX effectively is using this same ethernet cable from the host router as a BH. So anything connecting wirelessly or wired to the other ports will go thru this one ethernet cable from the host router to the EAX. This is NOT MESH though.
Oblique
So I note it has 4 ethernet ports - but can I use one of them as ethernet backhaul to the original router? I have an Ethernet cable to achieve this but I am not sure if it is compatible
Nov 12, 2023Guru - Experienced User
