Ru123
Jan 10, 2025Aspirant
Trouble with Xbox connections
Does the rs300 have full UPnP compatibility? I have two Xbox ones and cannot use both on online games at the same time. If one’s turned off it’s fine. All other consoles and devices fine. I have tr...
Jan 11, 2025Guru - Experienced User
Leave uPnP enabled.
Check on the RS web page under Advanced Tab/Setup/WAN setup for NAT Filter. Set NAT filter from Secure to OPEN.
This is needed if you have two more game consoles online at the same time and getting OPEN NAT Staus in games. Found this years ago.
I have tried with the default UPnP settings, I have tried port forwarding with UPnP off, I have tried reserving the IP addresses.
From what I can find online if these options don’t work it’s highly likely the router won’t support two Xboxes at once.
Is there a solution that anyone knows of?
Ru123
Jan 11, 2025Aspirant
Thank you both. They’re two different xbox accounts.
I did find that WAN setting and set NAT to open so that’s not it either unfortunately.
