Ru123
Jan 10, 2025Aspirant
Trouble with Xbox connections
Does the rs300 have full UPnP compatibility? I have two Xbox ones and cannot use both on online games at the same time. If one’s turned off it’s fine. All other consoles and devices fine. I have tr...
Ru123
Jan 11, 2025Aspirant
Thank you both. They’re two different xbox accounts.
I did find that WAN setting and set NAT to open so that’s not it either unfortunately.
Jan 12, 2025Guru - Experienced User
Did you hard power OFF the xboxes and then reboot the RS router after you set NAT Filter to OPEN? After router was bacdk to ready, power ON one xbox and check to see if it's signs on and then check NAT status on it's dash board. Then turn on the 2nd game console?
How are the game consoles connected to the router? Wired is preferred. Can try wireless as well.
- Ru123Jan 14, 2025AspirantThanks, yes I have done all of that - the NAT status on both is actually open and they will both load into games but then the internet will completely drop out.
They’re both wireless. We have fttp so it’s a standard nbn box.
I have swapped back to the isps router until I can work out how to fix this, and the Xbox’s are working perfectly again.- FURRYe38Jan 14, 2025Guru - Experienced User
If you put the ISP router back online, try the Orbi system in AP Mode using this PDF process and see if both connected to the Orib system still have problems:
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
