Ru123
Jan 11, 2025Aspirant
Trouble with Xbox connections
Does the rs300 have full UPnP compatibility? I have two Xbox ones and cannot use both on online games at the same time. If one’s turned off it’s fine. All other consoles and devices fine. I have tr...
Ru123
Jan 14, 2025Aspirant
Thanks, yes I have done all of that - the NAT status on both is actually open and they will both load into games but then the internet will completely drop out.
They’re both wireless. We have fttp so it’s a standard nbn box.
I have swapped back to the isps router until I can work out how to fix this, and the Xbox’s are working perfectly again.
Jan 14, 2025Guru - Experienced User
If you put the ISP router back online, try the Orbi system in AP Mode using this PDF process and see if both connected to the Orib system still have problems:
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
