Jimmdean
Oct 18, 2024Aspirant
Unable to use LAN aggregation on RS280 with VLAN tagging enabled
I have to use VLAN tagging for my internet, but LAN aggregation is disabled along with WAN aggregation when you have VLAN enabled. Is this a technical limitation? I'm no expert on VLANs, but I woul...
- Nov 04, 2024
Sorry, we've looked into this and it is a limitation on RS300 and RS280 that the VLAN function and the link aggregation function cannot be both enabled at the same time.
Oct 18, 2024Guru - Experienced User
Ya something that may not be supported in that kind of configuration. Let see if NG can help with some feedback on this one.
BH_C
Oct 20, 2024NETGEAR Expert
Looks it's a known issue and we still work on it.
- JimmdeanOct 23, 2024Aspirant
I've considered disabling the VLAN temporarily to configure the lan aggregation, then re-enabling the VLAN to see if they can co-exist when done in that order. Maybe you can warn me against that if you know it will not be successful.
- BH_COct 24, 2024NETGEAR Expert
Hi Jimmdean , we checked this process, and, sorry, it will not work. It currently does not allow both settings to be enabled. We still work to find a soliution.
- BH_CNov 04, 2024NETGEAR Expert
