Jimmdean
Oct 18, 2024Aspirant
Unable to use LAN aggregation on RS280 with VLAN tagging enabled
I have to use VLAN tagging for my internet, but LAN aggregation is disabled along with WAN aggregation when you have VLAN enabled. Is this a technical limitation? I'm no expert on VLANs, but I woul...
- Nov 04, 2024
Sorry, we've looked into this and it is a limitation on RS300 and RS280 that the VLAN function and the link aggregation function cannot be both enabled at the same time.
BH_C
Oct 24, 2024NETGEAR Expert
Jimmdean wrote:
I've considered disabling the VLAN temporarily to configure the lan aggregation, then re-enabling the VLAN to see if they can co-exist when done in that order. Maybe you can warn me against that if you know it will not be successful.
Hi Jimmdean , we checked this process, and, sorry, it will not work. It currently does not allow both settings to be enabled. We still work to find a soliution.
BH_C
Nov 04, 2024NETGEAR Expert
