William3087
Aug 07, 2025Aspirant
Update doesn't fix the upload speed i have 2gig speed symmetrical
this update doesn't fix the upload speed i have 2gig speed symmetrical and when i do a speed test with ookla speed test app i get 300mbps max
Aug 07, 2025Guru - Experienced User
What which model router do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Which ISP are you connected too?
How are you testing the speeds? Ethernet or wireless PC?
Has a factory reset been performed after loading the new FW and speed re-tested?
- William3087Aug 07, 2025Aspirant
The network configuration includes an Adtran ONT, a Netgear RS500 router, and a Fidium fiber connection providing 2 Gbps symmetrical service. The network utilizes Cat 6 cabling. Testing is being conducted on a Samsung S24 Ultra and a Galaxy Tab 9. The gaming PC is achieving the full 2 Gbps speed. The router has been factory reset, and the ONT has been rebooted.
- FURRYe38Aug 07, 2025Guru - Experienced User
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
So the gaming PC is getting 2Gb in both directions thru the router and the Samsung wireless devices are not?
the ONT that my internet provider gave me doesn't have a label of the model
