OsgoodeMediocre
Dec 25, 2025Aspirant
Upgraded WNR2000v1 Wireless Router, but no cable port
Good afternoon, I recently received an email that my WNR2000v1 Wireless Router was nearing it's end of support and I should get a replacement if I want to maintain my security levels. I purchase...
OsgoodeMediocre
Thank you for the reply. I went back to get the info you requested and discovered the hardware isn't Netgear but another manufacturer. Something that I should've done before ordering the router.
I guess I'll take this as a teaching moment.
Regards
- StephenBDec 26, 2025Guru - Experienced User
How old is that hardware? It is possible that an upgrade could give you better performance.
Netgear does make gateways (modem+router) that have a coax connection.
