OsgoodeMediocre
Dec 25, 2025Aspirant
Upgraded WNR2000v1 Wireless Router, but no cable port
Good afternoon, I recently received an email that my WNR2000v1 Wireless Router was nearing it's end of support and I should get a replacement if I want to maintain my security levels. I purchase...
OsgoodeMediocre
Thank you for the reply. I went back to get the info you requested and discovered the hardware isn't Netgear but another manufacturer. Something that I should've done before ordering the router.
I guess I'll take this as a teaching moment.
Regards
Dec 26, 2025Guru - Experienced User
OsgoodeMediocre wrote:I went back to get the info you requested and discovered the hardware isn't Netgear but another manufacturer
How old is that hardware? It is possible that an upgrade could give you better performance.
Netgear does make gateways (modem+router) that have a coax connection.
