jajaxxon
Dec 15, 2024Aspirant
Upgrading to a RS600 Nighthawk Router
Upgrading our network to an RS 600 Nighthawk for a number of reasons, (coverage, speed, capacity) from an older Nighthawk RAX series Any upgrade or conversion tips any of you have for the RS600? ...
- Dec 15, 2024
You can first set up the RS router off line while you have the older router still online.
Setup using a wired PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Use same SSID name and password for the wireless network.
Can use same channels.
After the RS is staged and mostly setup, power ON the RS near the out going router. Reboot the ISP modem or ONT. Disconnect the old router from the ISP modem or ONT and connect to the RS. After the RS is ready, turn OFF the out going router and remove it. Your wifi devices should have auto migrated to the RS routers wifi.
Dec 15, 2024Guru - Experienced User
jajaxxon
Dec 18, 2024Aspirant
Thanks for the replies / suggestions
I did complete the RS600 install, a bit painful, had to work with Netgear, but up and running
Overall it seems to be working well - Macs, Cameras, iPads, Phones, garage, generally working well
One periodic glitch with my Mac, wife's works great, separate post on that issue
Thanks all
