Clonea1
Aug 26, 2024Aspirant
Upload speeds RS700 are slow when compared to etherneted laptop direct to cm3000
Slow upload speeds from rs700+cm3000 2gbit down / 300mb up service plan i am contracted for Comcast tech just left and did a meter-based speed test on the coax line. the coax line tested at 23...
- Aug 28, 2024
I called into support he had me disable QOS and first try the thing ripped
Clonea1
Aug 29, 2024Aspirant
now the next think and ill do more testing on this now that i know cable modem and router are running proper now i can work down the stream i need to figure out why devices connected via my insight managed switches (gc510p) are testing like this
(ill most likely create a new thread once i have some testing done)
Aug 29, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page. Full data from the download section please.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
- Clonea1Aug 29, 2024Aspirant
Pre amp removal and pre addition of splitter to cause -7dbmv tax
Cable Diagnostic
Status: Poor
Action:
[Partial Service]
If the Partial Service mode does not go away within a few hours (Click the Refresh button after each step):
1) Make sure the coaxial cable is tightly connected.
2) Remove any unnecessary splitters.
3) Replace any required ones.
4) Contact your service provider for troubleshooting help.
[Downstream Power Level]
Try these actions (Click the Refresh button after each step):
3) Replace any required splitters.CM Status: Good
Downstream Status: Poor
Downstream Power Level: Poor
Downstream power is poor (11.0dBmV). The recommended level is between -10dBmV to 10dBmV.Downstream SNR Level: Good
Upstream Status: Poor
Partial Service: Poor
Cable modem is in partial service mode. Your service provider might be under maintenance. Most of the time it won't affect your traffic and will automatically clear when work is complete.Upstream Power Level: Good
Current Time: Sun Aug 25 11:27:02 2024Startup Procedure
Acquire Downstream Channel: 399000000 Hz Locked
Connectivity State: OK Operational
Boot State: OK Operational
Security: Enabled BPI+
IP Provisioning Mode: Honor MDD IPv6 only
Downstream Bonded Channels
Channel LockedStatus Modulation ChannelID Frequency Power SNR Correctables Uncorrectables
1 Locked QAM256 4 399000000 Hz 10.8 44.4 0 0
2 Locked QAM256 1 381000000 Hz 11 44.5 12 0
3 Locked QAM256 2 387000000 Hz 10.9 44.5 8 0
4 Locked QAM256 3 393000000 Hz 10.8 44.5 0 0
5 Locked QAM256 5 405000000 Hz 10.6 44.3 0 0
6 Locked QAM256 6 411000000 Hz 10.5 43.8 0 0
7 Locked QAM256 7 417000000 Hz 10.4 44.2 0 0
8 Locked QAM256 8 423000000 Hz 10.2 44.1 0 0
9 Locked QAM256 9 429000000 Hz 10.1 44 0 0
10 Locked QAM256 10 435000000 Hz 10.2 44.1 0 0
11 Locked QAM256 11 441000000 Hz 9.9 44 0 0
12 Locked QAM256 12 447000000 Hz 10.2 44 0 0
13 Locked QAM256 13 453000000 Hz 10.1 44 0 0
14 Locked QAM256 14 459000000 Hz 10 43.9 0 0
15 Locked QAM256 15 465000000 Hz 10 43.9 0 0
16 Locked QAM256 16 471000000 Hz 10.1 43.8 0 0
17 Locked QAM256 17 477000000 Hz 9.9 43.8 0 0
18 Locked QAM256 18 483000000 Hz 10 43.8 0 0
19 Locked QAM256 19 489000000 Hz 10 43.7 0 0
20 Locked QAM256 20 495000000 Hz 9.8 43.6 0 0
21 Locked QAM256 21 501000000 Hz 9.8 43.6 0 0
22 Locked QAM256 22 507000000 Hz 9.9 43.7 0 0
23 Locked QAM256 23 513000000 Hz 9.8 43.7 0 0
24 Locked QAM256 24 519000000 Hz 9.8 43.6 0 0
25 Locked QAM256 25 525000000 Hz 9.9 43.7 12 0
26 Locked QAM256 26 531000000 Hz 9.8 43.6 14 0
27 Locked QAM256 27 537000000 Hz 9.9 43.6 9 0
28 Locked QAM256 28 543000000 Hz 10 43.6 0 0
29 Locked QAM256 29 549000000 Hz 9.7 43.5 0 0
30 Locked QAM256 30 555000000 Hz 9.8 43.5 10 0
31 Locked QAM256 31 561000000 Hz 10.3 43.7 14 0
32 Locked QAM256 32 567000000 Hz 10.3 43.7 10 0Upstream Bonded Channels
Channel LockedStatus ChannelType ChannelID SymbolRate Frequency Power
1 Locked ATDMA 3 5120 Ksym/sec 29200000 Hz 41.3 dBmV
2 Locked ATDMA 2 5120 Ksym/sec 22800000 Hz 41.3 dBmV
3 Locked ATDMA 1 5120 Ksym/sec 16400000 Hz 41.5 dBmV
4 Locked ATDMA 4 5120 Ksym/sec 35600000 Hz 41.5 dBmV
5 Not Locked Unknown 0 0 0 0.0
6 Not Locked Unknown 0 0 0 0.0
7 Not Locked Unknown 0 0 0 0.0
8 Not Locked Unknown 0 0 0 0.0Downstream OFDM Channels
Channel LockedStatus ProfileID ChannelID Frequency Power SNR/MER ActiveSubcarrier Unerror Correctable Uncorrectable
1 Locked 0 ,1 ,2 ,3 193 690000000 Hz 9.98 dBmV 42.7 dB 388 ~ 3707 1949071570 1641321612 887
2 Locked 0 ,1 ,2 ,3 194 957000000 Hz 8.08 dBmV 41.0 dB 148 ~ 3947 1983216713 1277918392 0Upstream OFDMA Channels
1 Not Locked 0 0 0 Hz 0 dBmV
2 Not Locked 0 0 0 Hz 0 dBmV - Clonea1Aug 29, 2024Aspirant
pre removal of amp and addition of splitter to bring down power level
Cable Diagnostic
Status: Poor
Action:
4) Contact your service provider for troubleshooting help.CM Status: Good
Downstream power is poor (11.1dBmV). The recommended level is between -10dBmV to 10dBmV.Downstream SNR Level: Good
Upstream Status: Good
Current Time: Sun Aug 25 11:11:41 2024Startup Procedure
1 Locked QAM256 4 399000000 Hz 10.9 44.4 0 0
2 Locked QAM256 1 381000000 Hz 11.1 44.5 12 0
3 Locked QAM256 2 387000000 Hz 11 44.5 8 0
4 Locked QAM256 3 393000000 Hz 10.9 44.4 0 0
5 Locked QAM256 5 405000000 Hz 10.7 44.3 0 0
6 Locked QAM256 6 411000000 Hz 10.6 43.8 0 0
7 Locked QAM256 7 417000000 Hz 10.5 44.2 0 0
8 Locked QAM256 8 423000000 Hz 10.2 44 0 0
9 Locked QAM256 9 429000000 Hz 10.2 44 0 0
10 Locked QAM256 10 435000000 Hz 10.2 44 0 0
11 Locked QAM256 11 441000000 Hz 10 43.9 0 0
12 Locked QAM256 12 447000000 Hz 10.3 43.9 0 0
13 Locked QAM256 13 453000000 Hz 10.2 43.9 0 0
14 Locked QAM256 14 459000000 Hz 10.1 43.8 0 0
15 Locked QAM256 15 465000000 Hz 10.2 43.8 0 0
16 Locked QAM256 16 471000000 Hz 10.3 43.8 0 0
17 Locked QAM256 17 477000000 Hz 10 43.6 0 0
18 Locked QAM256 18 483000000 Hz 10.1 43.7 0 0
19 Locked QAM256 19 489000000 Hz 10.1 43.7 0 0
20 Locked QAM256 20 495000000 Hz 9.9 43.5 0 0
21 Locked QAM256 21 501000000 Hz 9.9 43.5 0 0
22 Locked QAM256 22 507000000 Hz 10.1 43.6 0 0
23 Locked QAM256 23 513000000 Hz 9.9 43.6 0 0
24 Locked QAM256 24 519000000 Hz 10 43.6 0 0
25 Locked QAM256 25 525000000 Hz 10.1 43.7 12 0
26 Locked QAM256 26 531000000 Hz 9.9 43.6 14 0
27 Locked QAM256 27 537000000 Hz 10 43.4 9 0
28 Locked QAM256 28 543000000 Hz 10.2 43.5 0 0
29 Locked QAM256 29 549000000 Hz 9.8 43.3 0 0
30 Locked QAM256 30 555000000 Hz 9.9 43.3 10 0
31 Locked QAM256 31 561000000 Hz 10.4 43.5 14 0
32 Locked QAM256 32 567000000 Hz 10.4 43.4 10 0Upstream Bonded Channels
1 Locked 0 ,1 ,2 ,3 193 690000000 Hz 10.18 dBmV 42.8 dB 388 ~ 3707 1942524232 1636061877 887
2 Locked 0 ,1 ,2 ,3 194 957000000 Hz 8.18 dBmV 40.9 dB 148 ~ 3947 1976552318 1273421820 0Upstream OFDMA Channels
2 Not Locked 0 0 0 Hz 0 dBmV - FURRYe38Aug 29, 2024Guru - Experienced User
Power needs to come down a bit more I believe, should be between +7dbm and -7dbm.
Please post the event logs from the mode as well.
right correct, yeh i tried to post before and after and it told me 'access denied' and double posted the before
here is after deleting the amp fromt he line and adding a splitter that has a -7dbmv tax
Cable Diagnostic
Status: Good
Action:
Your setup looks fine. If you can't access the internet, make sure you properly activated the modem. If modem has been activated and you still can't access the internet, contact your service provider for troubleshooting help.
If you can access the internet but has other internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info.CM Status: Good
Downstream Status: Good
Downstream Power Level: Good
Current Time: Wed Aug 28 18:47:00 2024Startup Procedure
1 Locked QAM256 4 399000000 Hz 3.9 44.3 0 0
2 Locked QAM256 1 381000000 Hz 4.4 44.6 0 0
3 Locked QAM256 2 387000000 Hz 4.2 44.5 0 0
4 Locked QAM256 3 393000000 Hz 4.2 44.4 0 0
5 Locked QAM256 5 405000000 Hz 3.9 44.3 0 0
6 Locked QAM256 6 411000000 Hz 3.7 43.7 0 0
7 Locked QAM256 7 417000000 Hz 3.5 44.1 0 0
8 Locked QAM256 8 423000000 Hz 3.3 44 0 0
9 Locked QAM256 9 429000000 Hz 3.3 43.9 0 0
10 Locked QAM256 10 435000000 Hz 3.2 43.9 0 0
11 Locked QAM256 11 441000000 Hz 3.3 44 0 0
12 Locked QAM256 12 447000000 Hz 3.4 44 0 0
13 Locked QAM256 13 453000000 Hz 3.5 44 0 0
14 Locked QAM256 14 459000000 Hz 3.6 44 0 0
15 Locked QAM256 15 465000000 Hz 3.5 44 0 0
16 Locked QAM256 16 471000000 Hz 3.4 43.9 0 0
17 Locked QAM256 17 477000000 Hz 3.4 43.8 0 0
18 Locked QAM256 18 483000000 Hz 3.1 43.7 0 0
19 Locked QAM256 19 489000000 Hz 3.2 43.7 0 0
20 Locked QAM256 20 495000000 Hz 2.9 43.6 0 0
21 Locked QAM256 21 501000000 Hz 2.8 43.6 0 0
22 Locked QAM256 22 507000000 Hz 2.9 43.6 0 0
23 Locked QAM256 23 513000000 Hz 3.1 43.7 0 0
24 Locked QAM256 24 519000000 Hz 3 43.7 0 0
25 Locked QAM256 25 525000000 Hz 3.3 43.8 0 0
26 Locked QAM256 26 531000000 Hz 3.2 43.7 0 0
27 Locked QAM256 27 537000000 Hz 3.3 43.7 0 0
28 Locked QAM256 28 543000000 Hz 3.4 43.8 0 0
29 Locked QAM256 29 549000000 Hz 3.5 43.8 0 0
30 Locked QAM256 30 555000000 Hz 3.8 43.8 0 0
31 Locked QAM256 31 561000000 Hz 4 43.9 0 0
32 Locked QAM256 32 567000000 Hz 4.3 44.1 0 0Upstream Bonded Channels
1 Locked ATDMA 4 5120 Ksym/sec 35600000 Hz 48.3 dBmV
2 Locked ATDMA 2 5120 Ksym/sec 22800000 Hz 48.3 dBmV
3 Locked ATDMA 3 5120 Ksym/sec 29200000 Hz 48.0 dBmV
4 Locked ATDMA 1 5120 Ksym/sec 16400000 Hz 48.5 dBmV
1 Locked 0 ,1 ,2 ,3 193 690000000 Hz 3.08 dBmV 42.9 dB 388 ~ 3707 205841800 142411069 0
2 Locked 0 ,1 ,2 ,3 194 957000000 Hz 1.28 dBmV 41.0 dB 148 ~ 3947 209797070 138165917 16462Upstream OFDMA Channels
1 Locked 12 ,13 41 36200000 Hz 42.5 dBmV
There we go.
Please post the event logs from the modem as well.
so my speeds issue is no resolved so you want the log for curiosity?
because it has mac's in their and i would want to redact the public facing macs ..
ok so the full even logs not just the block at the bottom of diags is a bin file export that says this is only for netgear support when i clicked it i dont know if i feel comfortable publiclyz posting
Copy and paste the event log into work or word pad, remove all MAC addresses, then save off to PDF file to attach or copy and paste data in to a new post.
combined log file attached
i did a before, after, today
- FURRYe38Aug 30, 2024Guru - Experienced User
Ok, looks great now.
You should be good to go now on the CM modem.
Enjoy. 📡 - Clonea1Aug 31, 2024Aspirant
This is curious and of no impact but did i find a bug?
went to go test QOS tonight and found that the display reverted back to the 73mb even though this test has been re ran a few times
clicked into QOS saw this
re ran the test got this
clicked apply to 'save the test', QOS page reloads after the apply to this (no i did not re use the print screen i took a fresh one
re run the test and its where it should be, so is it saving off the old information and not updating it ? new bug ?
so i re re ran the test clicked apply and when the page refreshed it still is reading the 73 BH_C i think we have a bug, how do we report that ?
- BH_CAug 31, 2024NETGEAR Expert
The "Apply" buttonn does not save the speed test result. The old data could be the cache in the browser. If you open a new browser window in the Incognito mode to access the router's Web GUI, will you see the old test results?
yes in a new private browser the same is displayed, as well as the same from a different machine, and the odds of a second machine also having the same cached values is pretty low i would think
from my laptop in private
from a RDP with my server also in private
- Clonea1Aug 31, 2024AspirantAnd more of the same from my work laptop that has been in a bad for a week and half that I have been on vacation and pre dates me owning the rs700
Your screeshots last night show the QoS is not enabled, and today's screenshots have QoS enabled. They are different situations. Can you do this:
1. uncheck the QoS and click Apply to make the change effective.
2. run speed test (you should get expected speeds now)
3. check "Enable QoS" and click Apply.
4. Now you should have QoS enabled and get around the expected speeds when you run speed test
Yeh so i didnt include a full serius, if i let speed test manage QOS it caps me back at 75~ number, however if i set to manual and put in say 450 then i also test out at 350~
in this configuration speeds work as expected
i will disable and run steps one by one as you have detailed shortly
1. - off state what the page loads to
2. - re running the speed test
3. - enable QOS and apply
4. - after the apply and page reload this is what is presented
... its not letting me put a third print screen, but in that specific order of operations the value did update. i still thing this is a bug because you shouldn't have to disable run the test, reenable to lock in the values those should dynamically update and not require the toggling
results of disable of QOS, run test, re enable QOS and page reload
also when running the test its self it should not be bound by the QOS ceiling, as that could cause it to not see more available bandwidth being made available. it should run out side of the that rule set
"i still thing this is a bug because you shouldn't have to disable run the test, reenable to lock in the values those should dynamically update and not require the toggling"
Yes, I agree. We will work on it. Thanks.
