Yungb329
Oct 16, 2025Follower
VLAN ID 7
Hi, I am from Germany and recently got a Nighthawk RS100 WiFi 7 to use with my Fibre Modem. I got a PPPoe Login and the Information to set the VLAN ID 7. How do I get this to work?
- kevin456londonInitiate
HelloYungb329,
To set VLAN ID 7 on your Nighthawk RS100 for PPPoE in Germany, go to Advanced Settings > Internet Setup, enable VLAN/Bridge, set VLAN ID to 7, and enter your PPPoE credentials. Save and reboot to apply.
Best Regards,
Kevin London - FURRYe38Guru - Experienced User
I would log into the RS routers web UI and configure the WAN side from there under Advanced Tab/Internet Setup.
Contact the ISP to ensure you have the right PPPoE configuration and information for a router to use with there network.
