jessejames87
Oct 03, 2023Apprentice
Wall Mount rs700
curiosity here when I google rs700 wall mount the following website's description states its compatible with the rs700, then when you read the description on the site it states all wifi 7 devices, ho...
- Oct 04, 2023
So this is an email i just received from netgear.
Hi Jesse,
I just received an update that both RBEWM and RBEWMB works for RS700S. Please click the links below for reference.
https://www.netgear.com/home/wifi/mesh/rbewmb/?_ga=2.150311730.529212470.1696258521-850849134.1696258521#twister-list-block
https://www.netgear.com/home/wifi/mesh/rbewm/#twister-list-block
Thank you for choosing NETGEAR.
Warm Regards,
April | Technical Support Expert
So it seems even though the white only lists the orbi 970 series it is compatible with the RS700
schumaku
Oct 03, 2023Guru - Experienced User
Not sure where the RS700 product relation should come from. The RBEWM Data Sheet does date from 11Sep2003, with no signs of the RS700. Just the title looks to be misleading:
I believe the user is trying to point out that when searching for wallmounts for the RS700, that that path taken is confusing the way that it's described. Hopefully NG and make an announcement, if and when there maybe something to support the RS as we know there is already for the Orbi 7 systems.
- jessejames87Oct 03, 2023Apprentice
look at the photo when you search rs700 mount it gives the link to that mount but the description under the site says its also for the rs700 but when you go to the link it just started wifi 7 devices and nothing about rs700.
- schumakuOct 03, 2023Guru - Experienced User
Several parts show up when using the fill text site search, none shows up explicitly mentioning rs700 for me - various mounts however, rack mounts for switches or other Orbi systems. Not the world's greatest CMS in action here I'm afraid.
- BH_COct 03, 2023NETGEAR Expert
The wallmount works for RS700 as well. You were looking at the white version, and, since RS700 is black, you can use the black version in the twister.
https://www.netgear.com/home/wifi/mesh/rbewmb/#twister-list-block
From the Technical Specs, you can see RS700S is listed.
- FURRYe38Oct 03, 2023Guru - Experienced User
Wondering for those that come across the "white" version of the wall mount, couldn't there be some reference to those users looking to ensure they are informed to look at the black version for the RS700?
