jessejames87
Oct 03, 2023Apprentice
Wall Mount rs700
curiosity here when I google rs700 wall mount the following website's description states its compatible with the rs700, then when you read the description on the site it states all wifi 7 devices, ho...
- Oct 04, 2023
So this is an email i just received from netgear.
Hi Jesse,
I just received an update that both RBEWM and RBEWMB works for RS700S. Please click the links below for reference.
https://www.netgear.com/home/wifi/mesh/rbewmb/?_ga=2.150311730.529212470.1696258521-850849134.1696258521#twister-list-block
https://www.netgear.com/home/wifi/mesh/rbewm/#twister-list-block
Thank you for choosing NETGEAR.
Warm Regards,
April | Technical Support Expert
So it seems even though the white only lists the orbi 970 series it is compatible with the RS700
jessejames87
Oct 04, 2023Apprentice
Hi Jesse,
Warm Regards,
