jessejames87
Oct 03, 2023Apprentice
Wall Mount rs700
curiosity here when I google rs700 wall mount the following website's description states its compatible with the rs700, then when you read the description on the site it states all wifi 7 devices, ho...
- Oct 04, 2023
So this is an email i just received from netgear.
Hi Jesse,
I just received an update that both RBEWM and RBEWMB works for RS700S. Please click the links below for reference.
https://www.netgear.com/home/wifi/mesh/rbewmb/?_ga=2.150311730.529212470.1696258521-850849134.1696258521#twister-list-block
https://www.netgear.com/home/wifi/mesh/rbewm/#twister-list-block
Thank you for choosing NETGEAR.
Warm Regards,
April | Technical Support Expert
So it seems even though the white only lists the orbi 970 series it is compatible with the RS700
cvxdoc
Mar 22, 2024Aspirant
Searched for the wall mounts today. Both white and black Product Data Sheets now list Orbi 970 and RS700S.
