flyaway1999
Oct 07, 2024Tutor
which is the best channel to use for wifi 7 to take advantage of the 320mhz channel width
hi, basically the title. whats the best channel for this? because i dont see the option to be able to play with channel width settings....
Router2371
Dec 02, 2025Aspirant
So for my new rs500, I cannot get 320. Best I can do for 6g is to set it to 'up to 2.9gbps' and it will get to 160. No other combo of channels/speeds works to get 320. My ASUS router has no problem doing 320 for 6ghz. How can I get this rs500 to work at 320?
