Mckekmc
May 26, 2026Aspirant
Wi-Fi ping spikes every 10 seconds.
Ping jumps from around 5 ms to 100 ms every 10 seconds. The issue is reproducible only when connected via Wi-Fi. When connected to the router with an Ethernet cable, the problem does not occur. R...
WarmHelp_NTGR
May 28, 2026NETGEAR Expert
Hi Mckekmc
I have sent you a private message. Please kindly check it when you have a moment.
