nnpatel90
Jun 17, 2025Follower
Wi-Fi signal drops out for seconds
I'm currently having issues similar to what you're talking about. Wi-Fi signal drops out for seconds, whether I'm playing a mobile game like Evony TKR, or in a Microsoft Teams meeting. It's been supe...
Jun 18, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Try disabling Smart Connect then test. Try enabling Smart Connect and test.
Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
