nnpatel90
Jun 17, 2025Follower
Wi-Fi signal drops out for seconds
I'm currently having issues similar to what you're talking about. Wi-Fi signal drops out for seconds, whether I'm playing a mobile game like Evony TKR, or in a Microsoft Teams meeting. It's been supe...
BH_C
Jun 19, 2025NETGEAR Expert
If you have Smart Connect enabled, I suggest you disable Smart Connect, use different network name (SSID) for the 2.4GHz and the 5GHz, connect your devices to the 5GHz (if the range is not too far away), and see if it helps. You may just change the 2.4GHz SSID to xxx-2.4 to keep the 5GHz's SSID xxx unchanged.
