cowswith
Apr 01, 2025Initiate
WiFi radio 160MHz 5G band - stable channel selection (Nighthawk RS200)
Hi folks, was wondering if there was a good solution to stable channel selection on the 160MHz 5G band. I will set my unit to say channel 36 or 48 or so with excellent down speeds, up to 1800Mb, ...
Apr 03, 2025Guru - Experienced User
It'll let you change to the 80hz band. When you go into your settings, your "**** up to speed" is what sets the bandwidth. Set it down a notch from 4800mbps to 2400mbps. That'll narrow the bandwidth.
