TonyMemphis
Oct 19, 2025Tutor
Win11 "Can't connect to this network" error
I just switched over to fiber from ATT DSL (used their Pace modem/router). I bought a Nighthawk BE9300 to sue with our new service. I have connected three very new HP laptops, phones, tv's et...
- Oct 26, 2025
I finally got it working! I don't know much about network stuff, so I can't explain this very well. But what I ended up having to do is using netsh in a command window to assign "permission" to my SSID. That did it! I have no idea why I had to do that though. I'm just lucky that I remembered that issue from last time I had an issue.
I even took the internal card out thinkin it might be causing an issue!
Anyway, I bought a USB Wi-Fi stick (BrosTrend 6500). It is working well. I am getting speeds of around 61Mbps in my shop in the backyard. That's a whole lot better than my old setup.
Thanks again.
Oct 20, 2025Guru - Experienced User
TonyMemphis wrote:I have a HP Pavilion laptop that is a few years old.
What OS are you using? Win 11? Or something else?
TonyMemphis
Oct 20, 2025Tutor
I am using Win 11 and I keep it updated. The card drivers are that latest (which are several years old).
