TonyMemphis
Oct 19, 2025Tutor
Win11 "Can't connect to this network" error
I just switched over to fiber from ATT DSL (used their Pace modem/router). I bought a Nighthawk BE9300 to sue with our new service. I have connected three very new HP laptops, phones, tv's et...
- Oct 26, 2025
I finally got it working! I don't know much about network stuff, so I can't explain this very well. But what I ended up having to do is using netsh in a command window to assign "permission" to my SSID. That did it! I have no idea why I had to do that though. I'm just lucky that I remembered that issue from last time I had an issue.
I even took the internal card out thinkin it might be causing an issue!
Anyway, I bought a USB Wi-Fi stick (BrosTrend 6500). It is working well. I am getting speeds of around 61Mbps in my shop in the backyard. That's a whole lot better than my old setup.
Thanks again.
CrimpOn
Oct 20, 2025Guru - Experienced User
TonyMemphis wrote:USB stick option is nice in that I don't have to tear open the laptop.
These new WiFi modules are SO easy to replace. What is the model number of the HP Pavilion laptop?
TonyMemphis
Oct 20, 2025Tutor
I'm not sure. It is out in my shop. It is probably 4 years old or so? Can't remember. I remembered today that I had to send it back immediately after I received it because wifi didn't work. Interesting. It has been temperamental over the years.
I have changed the cards out (batteries and drives too) in our older Pavilions. Not too bad. I was thinking though, that the USB stick might be a better option. This laptop is a shop laptop. Said shop is a small building out back. I have been using an extender to get the signal out there (with the ATT Pacer router). My hope is that with the external antennas, I can eliminate the extender in the middle. I'll see what happens.
