TonyMemphis's avatar
Oct 20, 2025
Win11 "Can't connect to this network" error
I just switched over to fiber from ATT DSL  (used their Pace modem/router).    I bought a  Nighthawk BE9300 to sue with our new service.    I have connected three very new HP laptops, phones, tv's et...
  • TonyMemphis's avatar
    TonyMemphis
    Oct 27, 2025
    I finally got it working!  I don't know much about network stuff, so I can't explain this very well.  But what I ended up having to do is using netsh in a command window to assign "permission" to my SSID.  That did it!  I have no idea why I had to do that though.  I'm just lucky that I remembered that issue from last time I had an issue.
    I even took the internal card out thinkin it might be causing an issue!
    Anyway, I  bought a USB Wi-Fi stick (BrosTrend 6500).  It is working well.  I am getting speeds of around 61Mbps in my shop in the backyard.   That's a whole lot better than my old setup.
    Thanks again.
